10-20-2014 12:51 PM - edited 03-17-2019 12:37 AM
Hi Folks
I have a corporate Cisco IP 7962 and it is stating "You Have VoiceMail".
I login to Messages with my ID and the system states that I do not have any current or old
voicemail yet the handset MWI is red and the LCD screen has a flashing envelope and states "You Have VoiceMail"
Thx
10-20-2014 02:12 PM
Hi.
Try to dial MWI/off directory number and the light should turn off.
Than leave a new message on your own Mailbox and listen to it and see if light works as expected.
Let me know
Carlo
10-21-2014 07:20 AM
Hi Carlo
I left a new message, listened to it then deleted it. This seems to have cleared the "You have VoiceMail" issue and the handset is not red anymore. A five Star answer. *****
Much appreciated
Thx Jim
10-21-2014 08:25 AM
Hi Jim.
Glad that helped.
If you want, you can mark this discussion as answered so that others can easily find a solution if they have a similar query.
Thanks again
Carlo
