Problem UC560 + SIP Phone + SIP Trunk
heuristicsol
The scenario in which we find is the following:
SCENARIO:
A PBX UC560, has some phones using SIP and a SIP trunk.
1.- UC560 version
UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T4, RELEASE SOFTWARE (fc1)
2.- SIP Phones UC560
show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
0*                                 102        109          no                                         # SIP phone
104                                4          109          no                                         # SIP phone
150                             40004      133          no                                         # SIP phone
170                             40003      132          no                                         # SIP phone
171                             40002      91           no                                         # SIP phone
180                             40001      19           no                                        # SIP phone
2508205196                 -1         1366         yes                                         # SIP TRUNK
5...                             20001      109          no                                         # SIP phone
520                             20075      109          no                                        # SIP phone
3.- Troncal SIP
PROBLEMA
All SIP phones try to register with the SIP provider. The SIP trunk provider when it receives more than 10 attempts failed records of UC560 IP bans. The unit is operating as a SIP proxy and forward REGISTER requests from SIP phones to SIP trunk, which as soon as you to realize more than 10 attempts the UC560 IP is in the blacklist and can not make calls.
Below are some examples of debugging,
# debug ccsip messages
Sent:
REGISTER sip:sip.netelip.com:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.9:5060;branch=z9hG4bK82FC76C
To: <sip:520@sip.netelip.com>
Date: Mon, 18 Feb 2013 14:04:52 GMT
Call-ID: E797F5B-761911E2-8006B1F0-399A5411
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 1
Timestamp: 1361196292
CSeq: 3591 REGISTER
Contact: <sip:520@192.168.1.9:5060>
Expires:  3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.168.1.9:5060;branch=z9hG4bK82FD226A
To: <sip:0*@sip.netelip.com>
Call-ID: D9056E8-761911E2-8002B1F0-399A5411
Max-Forwards: 1
CSeq: 3589 REGISTER
Contact: <sip:0*@192.168.1.9:5060>
Expires:  3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.168.1.9:5060;branch=z9hG4bK82FE5AA
To: <sip:104@sip.netelip.com>
Call-ID: DAF79A8-761911E2-8003B1F0-399A5411
Max-Forwards: 1
CSeq: 3591 REGISTER
Contact: <sip:104@192.168.1.9:5060>
Expires:  3600
Supported: path
Content-Length: 0
Previous attempts result in authentication failure and the IP ban UC560.
Received:
SIP/2.0 403 Forbidden (Bad auth)
Via: SIP/2.0/UDP 192.168.1.9:5060;branch=z9hG4bK82FFB0;received=217.125.71.164;rport=41626
To: <sip:520@sip.netelip.com>;tag=as0787db9c
CSeq: 3592 REGISTER
Server: Netelip
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Content-Length: 0
Received:
Via: SIP/2.0/UDP 192.168.1.9:5060;branch=z9hG4bK8300198C;received=217.125.71.164;rport=41626
To: <sip:0*@sip.netelip.com>;tag=as1cb35a3c
CSeq: 3590 REGISTER
Server: Netelip
Content-Length: 0
Received:
Via: SIP/2.0/UDP 192.168.1.9:5060;branch=z9hG4bK83012088;received=217.125.71.164;rport=41626
To: <sip:104@sip.netelip.com>;tag=as139a9b22
CSeq: 3592 REGISTER
Server: Netelip
Content-Length: 0
QUESTION
How can we prevent you to realize SIP phone registration attempts against SIP trunk?, And thus prevent the IP provider's IP ban the user the UC560.
                                        # Telefono SIP
Chrysostomos_CY
Level 5
Level 5
This is very normal
Add the no-reg primary  into ALL the ephone-dns
Also you have to do the same for the rest
Dial peers , etc
Example:
ephone-dn  1  dual-line
number 0900 no-reg primary
dial-peer voice 20 pots
no sip-register
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Chrysostomos_CY
Level 5
Level 5
This is very normal
Dial peers , etc
Example:
no sip-register
