CUCM DID number is not directing to Extension
TM13
  I added additional DID number on our current CUCM, but it is not directing to the extension, it is directing to the current number auto answer, any idea?
Voice Gateway config:
dial-peer voice 1 pots
service aa
incoming called-number 99112233
dial-peer voice 2 pots
incoming called-number 99112234
direct-inward-dial
Translation Pattern on CUCM
Translation Pattern - 99112234
Called Party Transform Mask - 2234
Calling Party Transform Mask - 2234
Extension 2234 is our group number,
Any additional config needs?
Chris Deren
Please post full config as this is not enough info (i.e. no voip dial-peers, etc), also provide information such as version of CUCM, PSTN trunk type, i.e. PRI/FXO, etc and what are you dialing. Looks like your dial-peer 1 uses Auto Attendant TCL script as well, is that what you are expecting?
HTH,
Chris
