Cisco ASR1002-X Cisco 1-Port 10GE LAN-PHY Shared Port Adapter capacity
Hirmo
We are using Cisco ASR1002-X which has 2 pcs of Cisco 1-Port 10GE LAN-PHY Shared Port Adapter. we purchased this router to be able to reach 10GB utilization but the router is not passing 5GB. We are afraid the port is limited to 5GB but we are not sure.
below is the router show version
RouterX1#show ver
Cisco IOS XE Software, Version 03.16.02b.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S2b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 21-May-16 09:07 by xxxx
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
197R1 uptime is 4 days, 1 hour, 18 minutes
Uptime for this control processor is 4 days, 1 hour, 20 minutes
System returned to ROM by reload
System image file is "bootflash:/asr1002x-universalk9.03.16.02b.S.155-3.S2b-ext.SPA.b"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 1067057K/6147K bytes of memory.
Processor board ID FOX2152PAPD
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
6594559K bytes of eUSB flash at bootflash:.
Aries Fernandes
If not wrong, I am hoping you should have purchased the license to move beyond 5Gbps. The '
show platform hardware throughput level' should tell you how much you currently are at.
Aries
Aries Fernandes
Aries
Hello
The current throughput shows 5GB but the router has 10G card as you can see show platform. can we increase into 10G?
Router1#show platform hardware THroughput level
The current throughput level is 5000000 kb/s
Chassis type: ASR1002-X
Slot Type State Insert time (ago)
0 ASR1002-X ok 4d08h
0/0 6XGE-BUILT-IN ok 4d08h
0/1 SPA-1X10GE-L-V2 ok 4d08h
0/2 SPA-1X10GE-L-V2 ok 4d08h
R0 ASR1002-X ok, active 4d08h
F0 ASR1002-X ok, active 4d08h
P0 ASR1002-PWR-AC ok 4d08h
P1 ASR1002-PWR-AC ok 4d08h
Slot CPLD Version Firmware Version
0 14012203 16.3(2r)
R0 14012203 16.3(2r)
F0 14012203 16.3(2r)
