Frame Relay problem
ZAINALATTAS9656
Hello everyone
I'm trying to get my frame-relay working from router 1 to the router internet, I have added frame-relay maps for both according to the IP address, and also added the frame relay connection in the cloud itself, yet I am not able to ping the between the two routers. Any ideas on why is that? also I have OSPF enabled, which means I don't have to do static IP routing right?
Also, I was able to ping now I cannot.
plz help ASAP.
Thank you for your help.
0 Replies 0
