InterVlan routing with a Multilayer switch using IPV6/ Packet Tracer L
Fabián Perilla
Hello everybody,
I 'been trying to implement inter-vlan routing using a layer 3 switch (3560), my porpuse is to use ipv6 instead of ipv4. I want the endpoints to communicate each other (pinging between vlans), but it doesn't seem to work. I also searched on Internet how to configure step by step a Multilayer Switch using PT, however it still behaves the same. I suppose it could be a kind of bug from PT(Packet Tracer), but if you have any solution, error you could find in my lab and opinion about this, I really appreciate your time and effort to understand what I'm trying to say.
To get to what I want to achieve. I add the packet tracer LAB.
Thanks in advanced!.
Topology:
Note : the attachment file (PT file ) is added to check out the config.
 The command you need for this is "ipv6 unicast-routing" and you have it on the L3 switch. You problem might be related to a bug in the PC. I faced the same problem you had and when I replaced the PC, the ping worked.
5 Replies 5
@Fabián Perilla hi, this works well in in PKT. 8.2.1.0118 . tested.
Good luck
KB
Hi!!!
Thank you so much for your help. Have a nice day!.
You´re welcome.
 When labing with PacketTracer, always have a second guess about the devices bahavior. PacketTracert is a great tool but as any other simulator, it fails sometimes.
Plz find the error for me and solved it thanks
WhatsApp Image 2023-10-14 at 3.25.51 PM.jpegWhatsApp Image 2023-10-14 at 3.26.32 PM.jpeg
