IPv6 class-map or IOS problem
vision1919
Community Member
Hello, sorry because of my bad English at first,
I have a problem with my IPv6 ACL, IPv6 Class-map or IOS I'm not sure so I'm asking you.
I have one 1721 router with one Ethernet and one FastEthernet interface, on Fa interface is 3 subinterfaces, and Eth interface is connected to 10 Mbps link to another 1721 router. I'm working on QoS for VoIPv6. My softphone emulator address is FEC2::1/64.
This is my configuration:
class-map match-any v6
   match access-group name v6
  policy-map v6
   class v6
    set ip dscp ef
ipv6 access-list v6 permit FEC2::/64 any
Question is, why is output of command show policy-map interface Fa0/0 showing that not a single one packet of IPv6 is not beeing marked:
R1#sho policy-map interface fa0
  FastEthernet0
   Service-policy input: v6
     Class-map: v6 (match-any)
       0 packets, 0 bytes
       5 minute offered rate 0 bps, drop rate 0 bps
       Match: access-group name v6
         0 packets, 0 bytes
         5 minute rate 0 bps
       QoS Set
        ip dscp ef
           Packets marked 0
     Class-map: class-default (match-any)
       92 packets, 9134 bytes
       Match: any
This exact configuration, with IPv4 is working fine. My IOS version is c1700-y-mz.122-11.T11.bin
If IOS version is too old, can you tell my what version will work so I can purchase it?
jstuxuhu0816
Community Member
Do you try to change the prefix-list?
If you are thinking of IPv6 prefix I tried everything. From /128 for single host to /64, nothing works.
Anyone?
