03-28-2012 07:21 PM - edited 03-01-2019 05:33 PM
Folks: I have this Cisco 2901 configured with PPPoE and IPv6 and connect it through a CO (DSLAM) to an Actiontec xDSL router. PPPoE connections are on FE0/0/0, through virtual template.
The Actiontec router gets NA and PD addresses succesfully and LAN PC connected to Actiontec router can surf the IPv6 Internet w/ no problem. However, Cisco 2901 can't reach the Actiontec router by its NA or TA public IPv6 address. A 'stupid' workaround is to manually add a route w/ the virtual access. It is stupid cuz each new connection will bring up a different virtual acess.
I guess this is a bug on 2901, but want to confirm with you guys first. Now the whole config:
version 15.2
hostname AEI_SV_Cisco_2091
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ipv6 unicast-routing
ipv6 dhcp pool HE
prefix-delegation pool HE-48
address prefix 2001:470:1F05:7A::/64
ipv6 cef
ip dhcp pool default
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 10.10.10.1
ip dhcp pool dslam1
network 10.11.11.0 255.255.255.0
default-router 10.11.11.1
dns-server 10.11.11.1
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
vpdn enable
crypto pki trustpoint TP-self-signed-3962993046
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3962993046
revocation-check none
rsakeypair TP-self-signed-3962993046
crypto pki certificate chain TP-self-signed-3962993046
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33393632 39393330 3436301E 170D3131 31313232 31363132
31335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39363239
39333034 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E6AF 1640A998 F13E9F8B EB9E404C F0D6E105 8DE05E45 9C9C525A 5AAEAF59
456A4578 1C0E283C 39B3751D 3F362D64 13FACD69 A92C31BA 6D2EEFBE 52BCC70C
73359968 2F76B830 A978BD5F 9A86903F C12BB00B C35C47D1 BADBE727 773E205D
A839969D FE3854B3 26E93F21 63DC4E57 D4C44821 FBE88BAA 4A1D5565 DA416138
3A7D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14BA6DEA 79E4742D 4878C88E D014C7A3 8022546A FE301D06
03551D0E 04160414 BA6DEA79 E4742D48 78C88ED0 14C7A380 22546AFE 300D0609
2A864886 F70D0101 05050003 818100CE C6732F7E 6AB385C5 5BF4E241 BE179F5D
E7C5CC78 2BFB33EC 3181D4D2 90981D2B 1106205F A3C5FEE8 E78A013B ABF3F5E0
52772A22 F3A0A24C C4F62DDB E2E6A21D AC75772B 6FEC9323 3DFC4165 CC645E62
5C8F5842 18B8DF5B C3E3C39C EBB60D3E E7ADA89B A72FB468 92F77F0A A33B5591
F5048271 F074C64E 38291F93 848F09
quit
license udi pid CISCO2901/K9 sn FCZ15489123
username admin privilege 15 secret 5 $1$.CdN$d0DXERD9PqUtu6XPilTv/.
username chap password 0 chap
bba-group pppoe global
virtual-template 1
sessions max limit 256
interface Tunnel0
description Hurricane Electric IPv6 Tunnel Broker
no ip address
ipv6 address 2001:470:1F04:7A::2/64
ipv6 enable
tunnel source 173.13.177.215
tunnel mode ipv6ip
tunnel destination 72.52.104.74
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip nat allow-static-host
ip nat enable
ip virtual-reassembly in
shutdown
duplex auto
speed auto
ipv6 enable
ipv6 dhcp server HE1
interface GigabitEthernet0/1
ip address 173.13.177.215 255.255.255.240
ip nat outside
ip nat enable
duplex auto
speed auto
interface FastEthernet0/0/0
ip address 10.11.11.1 255.255.255.0
ip nat inside
ip nat enable
duplex auto
speed auto
ipv6 address 2001:470:1F05:7A::1/64
ipv6 enable
ipv6 nd managed-config-flag
ipv6 nd other-config-flag
ipv6 dhcp server HE
pppoe enable group global
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
interface Virtual-Template1
mtu 1492
ip unnumbered FastEthernet0/0/0
ip nat inside
ip nat enable
ipv6 enable
no ipv6 nd ra suppress
ipv6 dhcp server HE
peer default ip address dhcp-pool dslam1
peer default ipv6 pool HE
ppp authentication chap
no routing dynamic
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 173.13.177.222
access-list 1 permit any
ipv6 route ::/0 Tunnel0
ipv6 local pool test 2001:470:7007::/48 64
ipv6 local pool HE-48 2001:470:8008::/48 64
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input all
transport output all
line vty 5 15
privilege level 15
login local
transport input all
scheduler allocate 20000 1000
end
See both IPv4 and IPv6 are using virtual template to get PPPoE work. Everything's working fairly well on IPv4. I can ping from cisco to the 10.11.11.x address on Actiontec router. But with IPv6, I can't ping 2001:470:1f05:7a:: address on Actiontec router. The correct route through virtual-access is not installed, or the F0/0/0 interface doesn't pass the IPv6 traffic to the corresponding virtual access interface:
AEI_SV_Cisco_2091#sh ipv6 route
IPv6 Routing Table - default - 7 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
B - BGP, R - RIP, I1 - ISIS L1, I2 - ISIS L2
IA - ISIS interarea, IS - ISIS summary, D - EIGRP, EX - EIGRP external
ND - Neighbor Discovery, l - LISP
O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
S ::/0 [1/0]
via Tunnel0, directly connected
C 2001:470:1F04:7A::/64 [0/0]
L 2001:470:1F04:7A::2/128 [0/0]
via Tunnel0, receive
C 2001:470:1F05:7A::/64 [0/0]
via FastEthernet0/0/0, directly connected (this sounds correct, but I'm not able to reach client from this interface)
L 2001:470:1F05:7A::1/128 [0/0]
via FastEthernet0/0/0, receive
S 2001:470:8008::/64 [1/0]
via FE80::21F6:88C4:497E:6F9C, Virtual-Access2.2
L FF00::/8 [0/0]
via Null0, receive
Can some help? Thanks!
Henry
