Problems Routing IPv6 between two different routers
AndrePCM2M
Hello All.
Here at my company, we work with one RV320 as the main router and other two cisco routers for R&D.
In the R&D routers, we work with IPv6 and, for each one , we set one IPv6 (2001:db8:5:1::5/64 , 2001:db8:5:1::6/64) and for each one we set a subnet mask (2001:db8:3:7::/64, 2001:db8:3:8::/64)  respectively.
The problem is that, when I try to ping or tracert from my computer the subnets both of them uses the 2001:db8:5:1::5 as gateway, so, just one of them work properly.
I have tried to set the "Static routing table" from my RV320 pointing each subnet to his router but, it didn't work.
How can I do it properly?
Any advice about how to set the correct gateway for each subnet?
Thank to all
johnd2310
Level 8
Level 8
Can you draw up a diagram of your setup? I am not sure what you mean with subnet mask (2001:db8:3:7::/64, 2001:db8:3:8::/64)
John
**Please rate posts you find helpful**
