Wrong Solution: Cisco Networking Academy Networking Essentials
L057-50UL
Community Member
After pressing "Check":
After pressing "Show Me":
IPv6 addresses can only be shortened once using the "::" notation.
The address
fe80::6678:9101::34ab is invalid because it uses "::" twice, which creates ambiguity about how many zero blocks should be inserted.
The rule is that you can replace the longest contiguous sequence of zero blocks with "::", but only once in the entire address to ensure it can be uniquely expanded.
Please fix this
Rich R
Hi @L057-50UL this is a technical forum mostly used by other people just like you - and there's nothing any of us can do about netacad.
You are trying to report an issue with some Cisco (third party) software.  The correct channel for reporting that is with the provider of the software - not here in a Cisco technical forum.
Login to netacad, click on your profile (top right) and select Support.  If you can't find the right option there then their standard answer is: "Your Instructor should be your first point of contact. They can answer your Networking Academy questions or contact the support desk for you. You can contact your instructor by using the message feature inside your course."
It looks like they don't let you contact support directly!
You could also try contacting them on their social media links at the bottom of their homepage.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
