599 Error with CURL Example
GaryFurash
Visitor
When I try to use the example from
https://developer.cisco.com/docs/axl/#!hello-world-with-curl
passing a user name and password I get an empty 559 response., with a message of none.
<div id="content">
<div id="content-header">HTTP Status 599 - </div>
<p>
<b> type: </b> Status report </p>
<p>
<b>message: </b>
</p>
<p>
<b>description: </b> http.599 </p>
</div>
Curl Command
curl -k -u [user]:[password] -H "Content-type: text/xml;" "SOAPAction:CUCM:DB ver=11.5" -d @request.xml https://ddscucmpub:8443/axl/
dstaudt
The HTTP 599 error indicates that you are requesting an AXL version that is not supported by the CUCM (see details about how CUCM and AXL versions are related).
You will need to update '8.5' in both the xmlns:ns namespace URL in the XML document, as well as in the SOAPAction header in the command to reflect the target version - e.g. 11.5 for CUCM v11.5.
Some other issues in the sample XML have also now been fixed/published to get it working with CUCM 12.5 (which is a bit stricter when parsing the request XML), please re-copy the XML sample as needed.
dstaudt
I got it to work with this
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
    <soapenv:Header/>
    <soapenv:Body>
        <ns:executeSQLQuery sequence="?">
            <sql>select lg.name as LineGroup,n.dnorpattern,dhd.hlog from linegroup as lg inner join linegroupnumplanmap as lgmap on lgmap.fklinegroup=lg.pkid inner join numplan as n on lgmap.fknumplan = n.pkid inner join devicenumplanmap as dmap on dmap.fknumplan = n.pkid inner join device as d on dmap.fkdevice=d.pkid inner join devicehlogdynamic as dhd on dhd.fkdevice=d.pkid order by lg.name</sql>
        </ns:executeSQLQuery>
    </soapenv:Body>
</soapenv:Envelope>
and this as the CURL
curl -k -u  xxx:xxxx -H "Content-type: text/xml;" "SOAPAction:CUCM:DB ver=11.5" -d @request.xml https://ddscucmpub:8443/axl/
