AXL 11.5 - udpatePhone fails
m.stolzenberg
I just tried to do an updatePhone request agains cucm 11.5.
I fired the following request:
<ns:updatePhone sequence="?">
         <!--You have a CHOICE of the next 2 items at this level-->
         <name>SEP00XXXXXXXXXX</name>
         <description>Example</description>
         <lines>
            <!--1 or more repetitions:-->
            <line ctiid="?">
               <index>1</index>
               <!--Optional:-->
               <label>Test</label>
               <!--Optional:-->
               <display>Test</display>
               <dirn uuid="?">
                  <pattern>233</pattern>
                  <routePartitionName uuid="?">intern</routePartitionName>
               </dirn>
               <recordingMediaSource>Gateway Preferred</recordingMediaSource>
                </line>
         </lines>
      </ns:updatePhone>
I get:
<faultstring>Item not valid: The specified numPlanId was not found</faultstring>
233/inter is an existing directory number
I tried the same with addLines
dstaudt
It's possible AXL is trying to lookup the directory number based on 'uuid="?"', which is invalid.  Can you try the request while removing the XXX="?" attributes..?
dstaudt
Many thanks.
After changing to:
<dirn>
the request is successful
Marcus
can you share the exact code for it
@m.stolzenberg wrote:
Many thanks.
After changing to:
<dirn>
Marcus
Thank you so much guys for sharing.
I got this huge project with over 6 thousands lines to update and I was doing it API, and this exactly same issue was killing my code. Thank you I remove the ="?", and it worked beatiful.
Thank you
