AXL error: empty telecastersubscribedservice.urllabel
istibekesi
I'm sending the following <updatePhone> AXL request as usual, updating phone services:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
   <SOAP-ENV:Body>
      <axl:updatePhone sequence="12" xmlns:axl="http://www.cisco.com/AXL/API/9.1">
         <name>SEP88755651BC56</name>
         <services>
            <service>
               <telecasterServiceName uuid="{80B3C4D0-DE22-6A7F-8A53-C09D82904E4F}"/>
               <name>EM</name>
               <url>http://192.168.5.18:8080/emapp/EMAppServlet?device=#DEVICENAME#&EMCC=#EMCC#</url>
               <urlButtonIndex>0</urlButtonIndex>
               <urlLabel/>
               <urlLabelAscii/>
               <serviceNameAscii>EM</serviceNameAscii>
               <phoneService>Standard IP Phone Service</phoneService>
               <phoneServiceCategory>XML Service</phoneServiceCategory>
               <priority>50</priority>
            </service>
         </services>
      </axl:updatePhone>
   </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
But I get the following AXL error in response:
<axlmessage>Cannot insert a null into column (telecastersubscribedservice.urllabel).</axlmessage>
In the request, the service part is exactly the same as i get it from getPhone, the <urlLabel> is empty in the getPhoneResponse too.
I understood: if I remove the <urlLabel/> item, the update is successful.
However I'm a bit confused, since I'm pretty sure this was working for years now.
I did not find any changes related to this item in the AXL schema documentation.
Furthermore, also very strange: in the database neither telecastersubscribedservice.urllabel, nor telecastercubscribedservice.urllabelascii are nillable. Why is it problem for empty <urlLabel/>, but does not for <urlLabelAscii/> then?
Reproduced on version 9.1 and 10.5.
lior look
Level 5
Level 5
Hi Istvan,
First of all, try to send the body SOAP with imported values only.
See at the AXL scheme what do you can to remove at this moment.
http://developer.cisco.com/site/axl/documents/previous-versions/index.gsp
In addition, the urlLabel is a string value so try to replace there something like NULL or "".
thedd
Try it like this:
         <services>
            <service>
               <telecasterServiceName uuid="{80B3C4D0-DE22-6A7F-8A53-C09D82904E4F}"/>NAME</telecasterServiceName>
               <name>EM</name>
               <urlLabel>EM</urlLabel> or <urlLabel>""</urlLabel>
               <urlLabelAscii/>
            </service>
         </services>
      </axl:updatePhone>
   </SOAP-ENV:Body>
