AXL SQL & Phone Protocol Specific Information
Gordon Ross
Level 11
Level 11
Where is the phone's Protocol Specific Information stored in the database?
GTG
Please rate all helpful posts.
tinghche
Level 6
Level 6
The Protocol information is in the table typedeviceprotocol
To retrieve what protocol a phone is using, you can use join to get from the database directly.
select  typedeviceprotocol.name from device inner join typedeviceprotocol on device.tkdeviceprotocol =  typedeviceprotocol.enum where device.name='SEPXXX'
Or, you can use getPhone API, to get the same information
Howard
But that's just the protocol used by the device. What about the other fields in that section in CCMAdmin. e.g.
It will be pretty complicated.
You can refer to the Common Table Relationships section in the AXL Data Dictionary document below for more details
https://developer.cisco.com/site/collaboration/management/axl/develop-and-test/documentation/latest-version/datadictiona…
Here is a screenshot of the table relationship to the phone.
Howard
