CUCM 10 SQL Query
marwa.ads
Frequent Visitor
Frequent Visitor
i am Trying to make soap request to executes sql query on CUCM 10.0 and seems that there's a problem in the request format,
any one can help? below is my code.
StringBuffer sb = new StringBuffer(2048);
        byte[] bArray = null; // buffer for reading response from
        Socket socket = null; // socket to AXL server
        OutputStream out = null; // output stream to server
        InputStream in = null; // input stream from server
        String sAXLSOAPRequest = "";
        String sAXLRequest = null; // will hold only the SOAP payload
        String authorization = CMUName + ":" + CMPass;
        authorization = new sun.misc.BASE64Encoder().encode(authorization.getBytes());
        sAXLSOAPRequest = "POST /axl/ HTTP/1.0\r\n";
        sAXLSOAPRequest += "Host:localhost:8443\r\n";
        sAXLSOAPRequest += "Authorization: Basic " + authorization + "\r\n";
        sAXLSOAPRequest += "Accept: text/*\r\n";
        sAXLSOAPRequest += "Content-type: text/xml\r\n";
        sAXLSOAPRequest += "SOAPAction: \"CUCM:DB ver=10\"\r\n";
        sAXLSOAPRequest += "Content-length: ";
        sAXLRequest = "<SOAP-ENV:Envelope "
                + " xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\"\n"
                + "  SOAP-ENV:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" >";
        sAXLRequest += "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" "
                + "xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\"> ";
        sAXLRequest += "<SOAP-ENV:Body> <executeSQL" + type + " sequence='1012121' > "; //1397055592533
        sAXLRequest += "<sql>" + sqlquery + "</sql>";
        sAXLRequest += "</executeSQL" + type + ">  </SOAP-ENV:Body> </SOAP-ENV:Envelope>";
        // finish the HTTPS Header
        sAXLSOAPRequest += sAXLRequest.length();
        sAXLSOAPRequest += "\r\n\r\n";
        // now add the SOAP payload to the HTTPS header, which completes the AXL
        // SOAP request
        sAXLSOAPRequest += sAXLRequest;
        try {
            CUCMOperations axl = new CUCMOperations();
            // Implement the certificate-related stuffs required for sending request via https
            X509TrustManager xtm = axl.new MyTrustManager();
            TrustManager[] mytm = {xtm};
            SSLContext ctx = SSLContext.getInstance("SSL");
            ctx.init(null, mytm, null);
            SSLSocketFactory sslFact = (SSLSocketFactory) ctx.getSocketFactory();
            socket = (SSLSocket) sslFact.createSocket(CMIP, Integer.parseInt(CMPort));
            in = socket.getInputStream();
            // send the request to the server
            // read the response from the server
            bArray = new byte[2048];
            int ch = 0;
            int sum = 0;
            out = socket.getOutputStream();
            out.write(sAXLSOAPRequest.getBytes());
            while ((ch = in.read(bArray)) != -1) {
                sum += ch;
                sb.append(new String(bArray, 0, ch));
            socket.close();
            // output the response to the standard output
            //System.out.println(sb.toString());
        } catch (UnknownHostException e) {
            System.err.println("Error connecting to host: " + e.getMessage());
            return "";
        } catch (IOException ioe) {
            System.err.println("Error sending/receiving from server: " + ioe.getMessage());
            return "";
            // close the socket
        } catch (Exception ea) {
            System.err.println("Unknown exception " + ea.getMessage());
            return "";
        } finally {
            try {
                if (socket != null) {
                    socket.close();
            } catch (Exception exc) {
                System.err.println("Error closing connection to server: " + exc.getMessage());
                return "";
        return sb.toString();
dstaudt
The code as listed needs to be updated to send the request to the actual UCM IP address, here:
What is the nature of the error/problem you are seeing?  Can you provide the XML request and response?
i receive the below response
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server</faultcode><faultstring>error: The document is not a executeSQLQuery@http://www.cisco.com/AXL/API/10.0: document element namespace mismatch expected "http://www.cisco.com/AXL/API/10.0" got ""</faultstring><detail /></soapenv:Fault></soapenv:Body></soapenv:Envelope>
