AXLAPI UpdateLine Problem with CSS
Hello everyone,
I have a Problem with my Script in PHP.
I will update callforward with API.
It runs put the Calling Search Space will delete imideatly by running the PHP Skript. I´ve tryed many constalations in my script but nothings run correct.
?php
require_once("include/connect_cucm.inc.php");
$pattern= "\+49" . $_GET['PT'];
$destination= $_GET['DES'];
$destinationempty = "";
$callingSearchSpaceName ="50650758-a276-7052-de87-37944067d9c3";
$routePartitionName="PT_Endgeraete";
$callForwardAll = array("callingSearchSpaceName"=>$callingSearchSpaceName,"destination"=>$destination);
$callForwardAllEmpty = array("callingSearchSpaceName"=>$callingSearchSpaceName,"destination"=>"");
$params = array('sql' => 'select lg.name as LineGroup, d.description As TName, n.dnorpattern, n.fkcallingsearchspace_cfb, dhd.hlog, cfd.cfadestination
      from linegroup as lg
      inner join linegroupnumplanmap as lgmap on lgmap.fklinegroup=lg.pkid inner join  numplan as n on lgmap.fknumplan = n.pkid
      inner join devicenumplanmap as dmap on dmap.fknumplan=n.pkid inner join  device as d on dmap.fkdevice=d.pkid
      inner join callforwarddynamic as cfd on cfd.fknumplan=n.pkid
      inner join devicehlogdynamic as dhd on dhd.fkdevice=d.pkid where n.dnorpattern="' . $pattern . '"');
$response = $client->executeSQLQuery($params);
#$CSS= array("callingSearchSpaceName"=>$LineGroup->fkcallingsearchspace_cfb);
if (empty($LineGroup->cfadestination)) {
$response = $client->updateLine(array("pattern"=>$pattern,"routePartitionName"=>$routePartitionName,"callForwardAll"=>$callForwardAllEmpty));
$response = $client->updateLine(array("pattern"=>$pattern,"routePartitionName"=>$routePartitionName,"callForwardAll"=>$callForwardAll));
}else {
First i´ve Search for a cfa.destiniation is set. if is set the code delete the callforwarding and set the new one.
But every time the css will delete too.
Many thanks
thedd
Could you provide the XMl you built to update the Line?
What exactly do you do with:
Below you find how i built my XML and it works.
I can change every single Call Forward setting with this:
<pattern>$dn</pattern><routePartition>$partition</routePartition>
<callForwardAll>
    <forwardToVoiceMail>f</forwardToVoiceMail>
    <callingSearchSpace/><destination>$cfa</destination>
</callForwardAll>
<callForwardBusy>
    <callingSearchSpace/><destination>$cfb</destination>
</callForwardBusy>
<callForwardBusy>
    <callingSearchSpace/><destination></destination>
</callForwardBusy>
<callForwardBusyInt>
    <callingSearchSpace/><destination>$cfbi</destination>
</callForwardBusyInt>
<callForwardNoAnswer>
    <callingSearchSpace/><destination>$cfna</destination>
<duration>$cfnar</duration></callForwardNoAnswer>
<callForwardNoAnswerInt>
    <callingSearchSpace/><destination>$cfnai</destination>
</callForwardNoAnswerInt>
<callForwardNoCoverage>
    <callingSearchSpace/><destination>$cfnc</destination>
</callForwardNoCoverage>
<callForwardNoCoverageInt>
    <callingSearchSpace/><destination>$cfnci</destination>
</callForwardNoCoverageInt>
<callForwardOnFailure>
    <callingSearchSpace/><destination>$cfcti</destination>
</callForwardOnFailure>
<callForwardNotRegistered>
    <callingSearchSpace/><destination>$cfu</destination>
</callForwardNotRegistered>
<callForwardNotRegisteredInt>
    <callingSearchSpace/><destination>$cfui</destination>
</callForwardNotRegisteredInt>
