Change Hlog setting based on CFA on DN
Mikael Hansson
Level 5
Level 5
I need to do a change of the Hlog (devicehlogdynamic) on all devices with a specific DN based on the CFA-status of that DN through AXL.
For example where DN=62990 and cfadestination is not empty or cfavoicemailenabled is true.
I know i have to do this in several steps:
1. get information if the DN is forwarded and which devices that DN belongs to.
2. update the Hlog on those devices
3. reset devices (doDeviceReset; isHardReset=false)
(if more than one device then do step 2 and 3 for each device)
Have anyone done this previously and have some code that you can share ?
Any help is appreciated. Even small contribution or examples on similar code
Mikael Hansson
npetrele
Here's a way to do step 1 with executeSQLQuery:
select device.name from device,numplan,devicenumplanmap,callforwarddynamic
         where numplan.dnorpattern = "<the dn>" and
         callforwarddynamic.cfadestination is not null and
         callforwarddynamic.cfavoicemailenabled = "t" and
         devicenumplanmap.fknumplan=numplan.pkid and
         callforwarddynamic.fknumplan=numplan.pkid and
         devicenumplanmap.fkdevice=device.pkid
Unless I'm misunderstanding your goals, the rest should be pretty straightforward, I think.
Some people prefer:
         where numplan.dnorpattern like "<the dn>" and
