04-17-2014 01:44 AM
Is it possible to change the PIN or password of an EndUser via AXL SQL?
The only password/PIN related field in the database schema that I can find is the passwordreverse field on the EndUser table.
GTG
04-17-2014 03:22 AM
Why not use the updateUser method besides using SQL?
04-17-2014 08:52 AM
The password as stored in the database is encrypted, so these values can't be directly written (app would need to implement the encryption). This password/pin encryption is provided by the AXL layer, i.e. via <updateUser>
