Create a Call Pickup Group without itself in "Current Associated Call Pickup Groups
fabien.bonic
Level 5
Level 5
Hi there,
I want to create a Call Pickup Group without itself in "Current Associated Call Pickup Groups" using AXL. Each time I create a Pickup Group, the new pickup group is added in the associated call Pickup Groups. How can I create one without this association ? Do I always need to update after the creation to remove this link ?
Thank you. Regards,
Fabien
npetrele
Hi Fabien,
Can you share the XML request you're using?
Hi Nick,
Here are the XML Request I’m using
Call Pickup Group Creation with no member:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/9.0">
<soapenv:Header/>
<soapenv:Body>
<ns:addCallPickupGroup sequence="?">
<callPickupGroup>
<pattern>20170310</pattern>
<description>fbo20170310</description>
<name>fbo20170310</name>
<members>
</members>
</callPickupGroup>
</ns:addCallPickupGroup>
   </soapenv:Body>
</soapenv:Envelope>
Response:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
<ns:addCallPickupGroupResponse xmlns:ns="http://www.cisco.com/AXL/API/9.0">
<return>{5054DC4D-50E3-8DA9-BACB-8DED5F600673}</return>
</ns:addCallPickupGroupResponse>
   </soapenv:Body>
</soapenv:Envelope>
Get Call Pickup Group:
<soapenv:Header/>
<soapenv:Body>
<ns:getCallPickupGroup sequence="?">
</ns:getCallPickupGroup>
   </soapenv:Body>
</soapenv:Envelope>
Response (where I see there is a member):
<soapenv:Body>
<ns:getCallPickupGroupResponse xmlns:ns="http://www.cisco.com/AXL/API/9.0">
<return>
<callPickupGroup uuid="{5054DC4D-50E3-8DA9-BACB-8DED5F600673}">
<usage>Call Pick Up Group</usage>
<routePartitionName/>
<members>
<member uuid="{42065C2C-A5D8-8348-93FA-672882AD60D0}">
<priority>1</priority>
<pickupGroupName uuid="{5054DC4D-50E3-8DA9-BACB-8DED5F600673}">fbo20170310</pickupGroupName>
</member>
</members>
<pickupNotification>No Alert</pickupNotification>
<pickupNotificationTimer>6</pickupNotificationTimer>
<callInfoForPickupNotification>
<callingPartyInfo>false</callingPartyInfo>
<calledPartyInfo>false</calledPartyInfo>
</callInfoForPickupNotification>
</callPickupGroup>
</return>
</ns:getCallPickupGroupResponse>
</soapenv:Body>
</soapenv:Envelope>
Update (same request than creation – with no member):
<soapenv:Header/>
<soapenv:Body>
<ns:updateCallPickupGroup sequence="?">
<members>
</members>
</ns:updateCallPickupGroup>
</soapenv:Body>
</soapenv:Envelope>
Get response after update:
<soapenv:Body>
<return>
<members/>
</callPickupGroup>
</return>
</soapenv:Body>
</soapenv:Envelope>
  Fabien
Sorry it took me so long to remember to address this.  This is a puzzler to me.  I'll have to try a few things.
Hi Fabien,
It looks like that's just the way it works.  If you add a call pickup group in the web UI, you get the same results.  So that's the default behavior.
Nick
