CUCM 10 Incorrect Response from function "listUser"
ivanlo001
In normal situation, "LUser" contains an element "telephoneNumber" (Lower case t)
However, starting from CUCM 10, "listUser" returns "LUser" with element "TelephoneNumber" (Capital letter T)
I suppose it is a typo of Cisco developer since the wsdl doesn't update it.
Ivan Lo
chao guo
Hi Lo,
I check the axlsqltoolkit of cucm 10.0  , find the listUser response of "LUser", and also find what you want like the following:
hope may help you
Hi chao guo,
That's why I want to point out that the axlsqltoolkit is wrong.
It should be
     name="TelephoneNumber"
instead of
     name="telephoneNumber"
Ivan Lo
bmennenga
Any response from Cisco on this?  Developers should not have to add code to check if CallManager version 10.X, then modify code to support TelephoneNumber for some functions and telephoneNumber from other functions.  This looks like a Cisco bug, one that Cisco needs to patch and fix to keep this field consistent across all functions and consistent across all versions.
wizzard344
https://tools.cisco.com/bugsearch/bug/CSCus72831/?referring_site=bugquickviewredir
This bug is fixed at the moment, but I have no time to order patches from reseller (I have no right to download myself), so I made a little kludge, which really works. I'm using C#.
Inside the generated by wsdl.exe "AXLAPIService.cs" find following class :
     public partial class LUser
Inside this class search for the property:
    [System.Xml.Serialization.XmlElementAttribute(Form=System.Xml.Schema.XmlSchemaForm.Unqualified)]
    public string telephoneNumber {
        get {
            return this.telephoneNumberField;
        set {
            this.telephoneNumberField = value;
Copy paste property and change telephoneNumber to TelephoneNumber to get this:
    public string TelephoneNumber {
        get {
        set {
Keep both properties inside class and build project, this worked for me.
P.S. Use telephoneNumber for requests and TelephoneNumber for responses.
