Directory Number AXL SOAP
patel-hitesh
I would like get the details from CUCM page Directory Number using AXLtoolkit SOAP API 11.5.
directoryNumberEdit.do?key=<pkid>
Please inform how to get all the fields with this page using SOAP AXL method or list of methods to all the fields.
npetrele
Perhaps you want getLine?  For example, this will return information about the Directory Number 3000.
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getLine sequence="?">
         <pattern>3000</pattern>
      </ns:getLine>
   </soapenv:Body>
</soapenv:Envelope>
npetrele
   <soapenv:Header/>
   <soapenv:Body>
      </ns:getLine>
   </soapenv:Body>
</soapenv:Envelope>
Thanks a lot Nicholas, That worked exactly required.
Also, have some query for the Line 1 on Device SEP3242332 (example) section on the same DirectoryNumber page. This section only comes up if you have the mapkey and devicekey.
Please inform if there is any SOAP method available to get those data and update with same soap axl method.
Appreciate your help.
