getLdapAuthentication is broken in 11.5
Jonathan Els
Level 5
Level 5
getLdapAuthentication is not working in 11.5.
The schema is really simple, and should work like getLDAPSystem:
<xsd:complexType name="GetLdapAuthenticationReq"/>
<xsd:element name="getLdapAuthentication" type="axlapi:GetLdapAuthenticationReq"/>
However, when you fire off this request, you're greeted with a delightful error message:
Request:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.5">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getLdapAuthentication/>
   </soapenv:Body>
</soapenv:Envelope>
Response:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <soapenv:Fault>
         <faultcode>soapenv:Server</faultcode>
         <faultstring>Item not valid: The specified Ldap Authentication was not found</faultstring>
         <detail>
            <axlError>
               <axlcode>5007</axlcode>
               <axlmessage>Item not valid: The specified Ldap Authentication was not found</axlmessage>
               <request>getLdapAuthentication</request>
            </axlError>
         </detail>
      </soapenv:Fault>
   </soapenv:Body>
</soapenv:Envelope>
Clearly this is a defect.  It's reproducible even with SoapUI.
This is pure speculation based on no testing...  but I'm going to hazard a guess that this is caused by the new LdapSearch options.  For some reason, despite appearing as a singleton in the UI, it supports a list method, as if there is an intention to (at least at some stage) support multiple LDAPSearch options per cluster.
8 Replies 8
npetrele
What version are you using?  This is working fine for me on CUCM 11.5.1.10000-6.  Are you sure you have LDAP Authentication defined via your CUCM web UI?
Hmmm, let me check...  If it's working for you, might have derped this one.
Well, here is the differing behaviour, which to me, is a bug.  It's debatable.
For LdapSystem, it returns empty values, as it is expected to:
<soap-env:Envelope xmlns:soap-env="http://schemas.xmlsoap.org/soap/envelope/">
  <soap-env:Body>
    <ns0:getLdapSystem xmlns:ns0="http://www.cisco.com/AXL/API/11.5"/>
  </soap-env:Body>
</soap-env:Envelope>
  <soapenv:Body>
    <ns:getLdapSystemResponse xmlns:ns="http://www.cisco.com/AXL/API/11.5">
      <return>
        <ldapSystem>
          <syncEnabled>false</syncEnabled>
          <ldapServer>Microsoft Active Directory</ldapServer>
          <userIdAttribute>None</userIdAttribute>
        </ldapSystem>
      </return>
    </ns:getLdapSystemResponse>
  </soapenv:Body>
</soapenv:Envelope>
For LdapAuthentication, it just breaks:
  <soap-env:Body>
    <ns0:getLdapAuthentication xmlns:ns0="http://www.cisco.com/AXL/API/11.5"/>
  </soap-env:Body>
  <soapenv:Body>
    <soapenv:Fault>
      <detail>
        <axlError>
        </axlError>
      </detail>
    </soapenv:Fault>
  </soapenv:Body>
</soapenv:Envelope>
They are both singleton configs.
This is how it works for me (you see I used 11.0, but 11.5 works, too):
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.0">
   <soapenv:Header/>
   <soapenv:Body>
   </soapenv:Body>
</soapenv:Envelope>
   <soapenv:Body>
      <ns:getLdapAuthenticationResponse xmlns:ns="http://www.cisco.com/AXL/API/11.0">
         <return>
            <ldapAuthentication uuid="{A8D94FF0-4627-EECC-0D8D-E2EE69123B32}">
               <authenticateEndUsers>true</authenticateEndUsers>
               <distinguishedName>my info</distinguishedName>
               <ldapPassword/>
               <userSearchBase>my search base</userSearchBase>
               <servers>
                  <server>
                     <hostName>my ldap ip</hostName>
                     <ldapPortNumber>389</ldapPortNumber>
                     <sslEnabled>false</sslEnabled>
                  </server>
               </servers>
            </ldapAuthentication>
         </return>
      </ns:getLdapAuthenticationResponse>
   </soapenv:Body>
</soapenv:Envelope>
Again, I have to ask, are you sure you defined LDAP Authenticatioin using the web GUI?  Also, I don't know why you're defining the namespace in the command, here:
That's being added by the soap library I'm using.  It's not resulting in an error in any other calls
Not sure why you're going on about defining in the GUI.  I shouldn't have to define it in the UI for the get to work on a singleton call.  It should return the element, or return nothing.  It should not raise an exception.  That's why I demonstrated the inconsistency between the two Reqs.
It works in the positive case.  It's the negative case where the bug is.
In general, a <getXXX> request should be intended to return a specific item, and if that item is not found, an error is returned:
* <getLdapSystem> will always return content, as the LDAP system settings are always present, even when disabled
* <getLdapSearch> returns an error similar to what you're seeing for <getLdapAuthentication> if no LDAP search sources have ever been configured.  Note, if an LDAP search source has been configured, but is disabled, then data is returned
* <getLdapAuthentication> returns the error described if no LDAP authentication source has ever been configured (similar to <getLdapSearch>).  If an LDAP authentication has ever been configured but is disabled, it is able to return data (which indicates the disabled state)
As there can only be one LDAP authentication target, having a <listLdapAuthentication> request would be superfluous.- there are <listLdapXXX> requests only for searches and directories, as those are the only entries with possible multiple items (note there is no <listLdapSystem> as that configuration item is always present.)
While there are a couple of things that make this overall situation a bit confusing, I'm not sure returning an empty object would be a better solution for <getLdapAuthentication>.  For example, <getPhone> for a phone that doesn't exist (or any other <getXXX> request) returns an error, vs. an empty phone object.
Is there a scenario or ambiguity that causes your application a problem with the current behaviour that can't be resolved by treating the currently returned error message as meaning 'no LDAP authentication target has been configured'..?
I can understand this reasoning for phones.  The use case for phones is different - the xsd explicitly requires a uuid or a name.
But this gets really confusing for singletons.  Here, I can send none, it's not validated in the schema but returns errors in some cases, and in others not.  So based on what you're saying, I now need to consider the scenario where ldapAuth was never configured, as only then will a get an error.  But you're also saying that it will return something (I haven't checked this) if there was a prior config, but it's disabled?  :/
If that's the expected behaviour distinguishing the two cases, then so be it.  Ultimately I want a reliable way to determine the UUID (if available) in all cases.  At least I understand it now... thanks!
Yep...in the case where a LDAP authentication configuration was ever done, but it is currently disabled, I get the below.  There doesn't appear to be a way (in the UI at least) to remove the config once made - only disable it:
  <soapenv:Body>
      <ns:getLdapAuthenticationResponse xmlns:ns="http://www.cisco.com/AXL/API/11.5">
        <return>
              <authenticateEndUsers>false</authenticateEndUsers>
              <distinguishedName>cn=administrator,cn=users,dc=ds-adfs,dc=sso,dc=com</distinguishedName>
              <ldapPassword/>
              <userSearchBase>cn=users,dc=ds-adfs,dc=sso,dc=com</userSearchBase>
              <servers>
                  <server>
                    <hostName>10.194.104.58</hostName>
                  </server>
              </servers>
        </return>
  </soapenv:Body>
</soapenv:Envelope>
