How do I create a line with certain configurations?
I'm really new with AXL so sorry if I'm being stupid.
I need to create a line and fill these values:
Directory Number information:
Directory Number, Route partition, Description, Alerting Name, ASCII Alerting Name, Active;
Directory Number Settins:
Calling Search Space;
Call Forward and Call Pickup Setting:
Forward All.
I tried to use SoapUI along with AXLAPI.wsdl file. When I click on addLine function there comes the XML code, but I don't get how I fill values like Directory Number, for example.
BjoernMartin
Well, that's no problem. There's a first time for everyone.
I think that's SOAPUI is a good choice to start with API request!
Here is an example of api call addLine:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/12.5">
    <soapenv:Header/>
    <soapenv:Body>
        <ns:addLine sequence="?">
            <line>
                <pattern>1000</pattern>
                <description>created by axl</description>
               <usage>Device</usage>
               <routePartitionName uuid="?">glo_intern</routePartitionName>
               <callForwardAll>
                  <callingSearchSpaceName uuid="?">CSS_National</callingSearchSpaceName>
                 <destination>1001</destination>
              </callForwardAll>
             <callPickupGroupName uuid="?">Pickup_Duesseldorf_00</callPickupGroupName>
            <alertingName>Home Office</alertingName>
            <asciiAlertingName>Home Office</asciiAlertingName>
            </line>
        </ns:addLine>
    </soapenv:Body>
</soapenv:Envelope>
Please look at Cisco Devnet - Cisco Administrative XML (AXL) webpage.
https://developer.cisco.com/site/axl/
Is very helpful!
best regards
BjoernMartin
    <soapenv:Header/>
    <soapenv:Body>
            <line>
               <callForwardAll>
              </callForwardAll>
            </line>
        </ns:addLine>
    </soapenv:Body>
</soapenv:Envelope>
Is very helpful!
best regards
Exactly what I needed, thank you!
npetrele
TIPS:
In some cases (rare), things like uuid="?" and sequence="?"  attributes among some others can cause errors.
(I'm talking about leaving them equal to "?" -- if you know the values that replace the ?,  that's fine).
I usually delete those in my XML requests. It's just force of habit now.
Also, some requests that return multiple responses (eg. lists, like listUser) will have these optional XML elements:
         <!--Optional:-->
         <skip>?</skip>
         <!--Optional:-->
         <first>?</first>
There's nothing wrong with using them, but don't leave them in with ? as the value. This will cause an error.
