Requests not returing information in SOAPUI
Joseph Jacobs
Level 4
Level 4
I was trying to understand the PAWS interface and was using SOAPUI.
I finally got (i believed) the correct Request syntax to do various requests but when i submitted the requests I'd get nothing back from the server.
The issue was synchronous vs asynchronous requests.
https://developer.cisco.com/media/PAWS_Developer_Guide/index.html?asynchronous_behavior.html
The sample requests as documented in the API guide, some would be set up for Asynchronous behavior and would have a generic WSA replyto address, but others would have the anonymous address.
For testing, I don't have a WSA server, so I needed to set the entry to Asynchronous.
Example from the API Guide:
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
    <SOAP-ENV:Header xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing">
        <wsa:Action>urn:getActiveVersion</wsa:Action>
        <wsa:MessageID>uuid:c37f60b9-92eb-4c1a-8de7-873b60adce19</wsa:MessageID>
        <wsa:ReplyTo>
            <wsa:Address>http://server/servlet/WSACallBackHandler</wsa:Address>
            <wsa:PortType xmlns:ns1="http://example.org">ns1:LocalPart</wsa:PortType>
        </wsa:ReplyTo>
        <wsa:To>https://server/platform-services/services/VersionService .VersionServiceHttpSoap11Endpoint</wsa:To>
    </SOAP-ENV:Header>
    <SOAP-ENV:Body>
        <getActiveVersion xmlns="server_url"/>
    </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
What I used in SOAPUI to get a response on my screen
        <wsa:ReplyTo>
            <wsa:Address>http://www.w3.org/2005/08/addressing/anonymous</wsa:Address>
        </wsa:ReplyTo>
    </SOAP-ENV:Header>
    <SOAP-ENV:Body>
        <getActiveVersion xmlns="http://services.api.platform.vos.cisco.com"/>
    </SOAP-ENV:Body>
Note the wsa:Address tag is different that the default tag as listed in the developer guide.
Just a heads up to anybody else who starts learning the PAWS api.
0 Replies 0
