When i am running below code- getting error - TypeError: tuple indices must be integers, not str
shree bhagwan parashar
Community Member
I am getting below error when i am running given code:
result = client.service.listPhone({'name':'SEPEXXXXD958F06'},{'name':'','model':''})
print(result)
for node in result['return']['phone']:
    print str(node['name']), str(node['model'])
(200, (reply){
   return =
      (return){
         phone[] =
            (LPhone){
               _uuid = "{51D5AC0A-E3F9-C05B-B446-4F1ACD6D0472}"
               name = "SEPEXXXXD958F06"
               model = "Cisco 7945"
Traceback (most recent call last):
  File "C:\Python27\Scripts\Listphone1.py", line 58, in <module>
Any help will be appreciated.
prasanth.ccvp
Frequent Visitor
Frequent Visitor
Hello
I am also having similar issue. Can you let me know, how you fixed the issue ?
Prasanth
npetrele
This is actually a Python/Soap Library issue.  I suggest you find out who supports your SOAP library for Python and get support there.  They'll probably need to see the AXL WSDL to debug it.
More details would be helpful (which SOAP library?).  If you can provide a small sample application project which demonstrates the problem, we may be able to get it working,
