Where Can i find the Cisco Unified CM AXL Schema Reference for CCM version 9
Osama Mahmoud
Hello ,
     I tried to search for the Cisco Unified CM AXL Schema Reference for CCM version 9 but i can only find the latest Schema (10.5) , May someone post the link to get this Schema .
Best Regards ,
Geevarghese Cheria
Hi Osama,
   I was not able to find the URL related to older cucm version. As mentioned in the guidelines Developers should always plan to implement support for the newest AXL schema available.
  Please refer the url  versioning for more details.
Thanks and Regards,
Geevarghese
https://developer.cisco.com/media/manager-xml-developer-guide/index.html?versioning.html
Error 404 now.
Where is all the DevNet stuff?
So many links are now 404.
Is AXL getting phased out?
Older versions of the AXL schema reference, data dictionary, etc. are available here:
https://developer.cisco.com/docs/axl/#!archived-references
The 9.0 link seems to be working for me, as well as a few others I tried.  If you're looking in a place other than the current AXL Docs page, let me know how you found it so we can update redirects as needed: https://developer.cisco.com/docs/axl/
AXL is definitely not going anywhere!
