Where we get cucm 11.5 WDSL Schema
vasu_hanu66
hi,
We have an application which uses 8.5 schema to update CIT routepoint for call forwarding to a number. not it got break due to upgrade to cucm 11.5. Could you please help in getting correct 11.5 WDSL main schema to do necessary changes.
npetrele
You can get the WSDL by logging into the CUCM web GUI and going to Application->Plugins click Find, and then download the Cisco AXL Toolkit.  You'll get a zip file that contains WSDLs for various versions including 11.5 (assuming you have 11.5 CUCM).
You can get the schema from DevNet at this link:
https://developer.cisco.com/site/axl/documents/latest-version/axl-soap.gsp
