Biometric on admin panel login
martinorob
Hi, even if I configure the global policy to use biometric authentication,
when I receive the duo push for my admin panel login, it not ask for may biometric authentication on my iPhone.
Other protected application ask me for the biometric auth.
What I’m wrong?
mkorovesisduo
Level 4
Level 4
Hi, biometric auth policy does not apply to Duo Admin Panel login. It can only be applied to Duo-protected applications.
The only configurable settings for admin panel login are described here: Managing Duo Administrators | Duo Security
what a pity!
I think it should be implemented as a feature since it is important to have “maximum” security in the admin panel.
thanks anyway
