A user is receiving phone calls instead of texts for his DUO prompt. He would like to receive Texts instead
endlessknot
He would like to receive Texts instead.
Please advise.
9 Replies 9
DuoKristina
Hi there @endlessknot!
Some applications support an automatic phone call or Duo Push at login, but there isn’t a Duo configuration that automatically texts an OTP code to a user at login. If you shared which application you’re using with Duo I could point you to the specific instructions for receiving an SMS passcode when logging in.
Duo, not DUO.
I opened a ticket and got help.
Thanks.
Do you want to update this thread with your solution?
Duo, not DUO.
Solution> Re activate DUO Push
Thanks @endlessknot for updating the thread to share your solution with the wider community! And Kristina for suggesting it
Please I am no longer receiving text messages for my School login! Why?
I requested, but the message didn’t come to my phone!
Please I need a quick response!
Sorry to hear you’re having problems, @Edet.
Unfortunately, Duo isn’t able to assist end-users of our customers directly. Duo support simply doesn’t have that access.
I recommend you contact your school’s help desk.
Duo, not DUO.
