Is it possible to configure duo MFA with ISE using its internal users
anis.ghorayeb
Is it possible to configure duo MFA with ISE using its internal users for authentication, not using external sources like AD ?
balaji.bandi
is this for device admin or VPN users :
check below guide for device admin using ISE Local users :
https://community.cisco.com/t5/security-knowledge-base/duo-mfa-integration-with-ise-for-tacacs-device-administration/ta-p/3882063
Note : Most use cases uses external source - like AD will be easy for managing users and making policies correctly.
i would recomend good video :
https://www.youtube.com/watch?v=daj4KqaeNNE
BB
DuoKristina
You might want to try this recently released Duo API integration in ISE 3.3 P1. It does not require use of the Duo Authentication Proxy.
https://www.cisco.com/c/en/us/td/docs/security/ise/3-3/admin_guide/b_ise_admin_3_3/b_ISE_admin_33_segmentation.html?bookSearch=true#integrate-duo-with-cisco-ise
Duo, not DUO.
