It is applicable to configure DUO with cisco SSL VPN ( remote access )
a ali
it is applicable to configure Two-Factor Authentication with DUO in Cisco SSL VPN ( remote access ), if I used the LOcal database of Cisco FTD as primary authentication, as after I checked the article I found it used LDAP or RADIUS server as a primary authentication
DuoPablo
Hi @AAli ,
Perhaps the following KB article will help regarding your inquiry: Can I use Duo to protect Cisco ASA local account logins?
Thanks!
DuoPablo
Hi @AAli ,
Thanks!
DuoKristina
Here are step-by-step instructions to add Duo via RADIUS for only secondary authentication on an ASA. You can keep primary set to local.
Duo, not DUO.
