No PUSH for logging in to Duo.com?
PGNd
I’ve got DuoMobile/Android PUSH working with numerous sites.
When I attempt to login to the Duo.com site itself, I’m given 3 options @ the “Confirm Your Identity” step:
(1) DuoPush
(2) SMS
(3) Call
(2) & (3) work fine.
But DuoPush, once selected/clicked never actually sends a Push – the item simply is selected/grayed-out, with label “Sending …” and never progresses/completes.
What needs to be done to get DuoPush working on Duo.com itself?
jamieis
Hey there @PGNd,
Did Duo Push ever work for you when logging into the Duo Admin Panel?
If not, or if you recently got a new phone you might need to activate push for your administrator user by following our docs here: https://duo.com/docs/administration-users#use-duo-push-for-administrator-authentication
Let me know if you have any other questions!
– Jamie
