3750ME Error
ruslanbelov
Hello!
I have cisco 3750ME. And there is an error
Jan 19 22:54:45.180: %OCE-3-MISSING_HANDLER_FOR_SW_OBJ_TYPE: Missing handler for 'non choice oce get next' function for type Midchain
What does it mean? Is that critical?
2 Accepted Solutions
Ganesh Hariharan
Hello!
Hi Belov,
An internal API request has been ignored because it was unexpected.
It is just an informational message.And this issue has beenfixed in version IOS 12.2(40)SE or later.Please upgrade into this version. Also
please refer the bug CSCsi51035 for additional information.
Hope that help out your query !!
If helpful do rate the valauble post.
Ganesh.H
Thank you!
Where i can get information about bug CSCsi51035?
Hi Belov,
Please see the below description from cisco regarding the bug detail
CSCsi51035 Bug Details
Traceback: %OCE-3-MISSING_HANDLER_FOR_SW_OBJ_TYPE
Symptom:
See traceback when an ARP request is received on a 3750-ME ES port for
an unknown IP address and we are attempting to put in ARP throttling
entry.
Conditions:
The traceback happens when we receive and resolve a ARP request for an
unknown IP address on an ES port and when ARP throttling entry was
attempted to put in place.
Workaround:
There is no work around. The traceback in this case is informational
and does not indicate a functional problem. No corrective action is
required.
Hope to help
Ganesh.H
Ganesh Hariharan
Hello!
Hi Belov,
Ganesh.H
Thank you!
Thank you!
Hi Belov,
Symptom:
entry.
Conditions:
Workaround:
required.
Hope to help
Ganesh.H
Thank you!
