Accedian AMN-1000-TE
rosbor1
Now that Cisco has acquired Accedian network I can seem to find a manual for a AMN-1000-TE device.  Anyone know where to find one of these?
AshSe
Hello @rosbor1
Let me try to help you locate a manual for the Accedian AMN-1000-TE device.
  1. Accedian's Official Website: Accedian typically provides product documentation, including user manuals, on their official website. Visit their support or resources section to search for the AMN-1000-TE manual.
  2. Cisco's Support Portal: If Cisco has indeed acquired Accedian, the documentation for Accedian products might eventually be migrated to Cisco's support portal. Check Cisco's website for any updates or product documentation.
  3. Contact Support:
  4. Search Online: Sometimes, manuals for older or niche devices can be found on third-party websites or forums. Be cautious when downloading files from unofficial sources to avoid malware.
  5. Reach Out to Your Vendor or Reseller: If you purchased the AMN-1000-TE through a vendor or reseller, they might have access to the manual or be able to request it on your behalf.
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  2. Always mark helpful and correct answers, it helps others find what they need.
  3. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
Thank you for the quick response.
Hey @rosbor1
If my response was helpful and resolved your query, it would be great if you could accept the solution. This will not only confirm that the issue is resolved but also help others in the forum who might face a similar situation.
Please feel free to reach out if you have any further questions.
BR
AshSe
