ASR 903 Adding Module while powered.
Morning All,
New to the forum and had a question regarding adding a module to a 903.
Module is a A900-IMA2Z
Been looking around and saw that you can replace a card without powering it down, but can you add a new card to the system without powering it down?
Figuring the answer is a definite no.
But was curious if this was a possibility?
Appreciate the advice.
balaji.bandi
yes you can add new card without powering down - take some time to recognise the card. check the Logs you see the progress and you need to configure the module config depends on requirement.
BB
balaji.bandi
BB
BB,
Thank you for the advice.
Worked like a charm.
Truly Appreciate it.
