ASR920 disable facility-alarm
Fabian Mauchle
Is it possible to disable the critical facility-alarm for the 'interface link-down' status, so the 'stat' led on the device doesn't turn red? (the interface is intended to be no shut, but normally down)
#show facility-alarm status
System Totals  Critical: 1  Major: 0  Minor: 0
Source                     Time                   Severity      Description [Index]
GigabitEthernet0/0/0       Jul 03 2015 13:46:23   CRITICAL      Physical Port Link Down [1]
(IOS-XE 03.14.01.S on ASR920)
7 Replies 7
Vinit Jain
Not sure if the below configuration is supported on the software version you are running but you can try using "no facility-alarm detect interface <int_type>"
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/command/ir-cr-book/ir-f1.html#wp1545311740
Hope this helps.
Vinit
--Vinit
Hi Vinit,
Thanks for the hint. Sadly this command is not valid on the ASR920. Only the "facility-alarm critical exceed-action" is available, but that doesn't help.
On which platform did you find the command? (on ASR1k?)
Fabian
Hello Fabian
i just noticed on the CCO documentation. this command is available starting 15.0(1)M release and it only says for 5400-XM series router.
What is the version that you are using? "show version | in image"
Vinit
--Vinit
System image file is "bootflash:/asr920-universalk9_npe.03.14.01.S.155-1.S1-std.bin"
you seem to be running one of the latest images. If the option is not supported in this release, then i dont think it will be supported in other releases.
Can you try to shutdown the link and see if the alarm clears. since the link is down, i dont think making it admin down will have any impact.
Hope this helps.
Vinit
--Vinit
Yes, when the interface is shut down, the alarm is cleared. The admin down state has severity 'info'. As soon as I do a 'no shut' the alarm is raised again.
Thanks for your help.
Thanks for the confirmation. I believe its good to keep the link in shutdown state if the link is not connected.
VInit
--Vinit
