Async5 ports on CiscoAS5850
Narius_fx
We have a problem
on Cisco AS5850, all unusable async ports are removed from running-config , but one of them , especially Async5/00-5/323 is unavailable to remove by any command of disabling and removing. At the end of sh run , there is line 5/00-5/323 that if I want to remove , it says that the vty port doesn't exist, but if I enter to interface , it goes in.
Please assist,
how can I remove that
Thank you
this is show run result
no ip domain-lookup
ip domain-name infocom.am
ip name-server x.x.x.x
controller E1 0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-semi-compelled
cas-custom 1
release-guard-time 50
seizure-ack-time 2
description FROM TANDEM -D-
controller E1 0/1
framing NO-CRC4
cas-custom 1
seizure-ack-time 2
controller E1 0/2
controller E1 0/3
controller E1 0/4
controller E1 0/5
controller E1 0/6
controller E1 0/7
controller E1 0/8
controller E1 0/9
controller E1 0/10
controller E1 0/11
controller E1 0/12
controller E1 0/13
controller E1 0/14
controller E1 0/15
controller E1 0/16
controller E1 0/17
controller E1 0/18
controller E1 0/19
controller E1 0/20
controller E1 0/21
controller E1 0/22
controller E1 0/23
interface FastEthernet6/0
ip address x.x.x.x x.x.x.x
ip route-cache same-interface
logging event link-status
duplex auto
speed auto
no cdp enable
interface GigabitEthernet6/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet6/1
no ip address
shutdown
negotiation auto
interface Async5/00
no ip address
interface Async5/01
no ip address
interface Async5/02
no ip address
interface Async5/322
no ip address
interface Async5/323
no ip address
interface Group-Async0
no ip address
encapsulation ppp
shutdown
async mode interactive
peer default ip address pool E1_pool
ppp authentication pap chap ms-chap ms-chap-v2
no group-range
ip local pool E1_pool x.x.x.x x.x.x.x
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no ip http server
no logging trap
tacacs-server host 10.10.10.254
call rsvp-sync
voice-port 0/0:1
voice-port 0/1:1
dial-peer cor custom
banner login ^CC
Welcome to ArmenCell
^C
line con 0
line aux 0
line vty 0 4
access-class 99 in
access-class 99 out
exec-timeout 112 51
transport input lat pad v120 lapb-ta telnet rlogin udptn
transport output lat pad v120 lapb-ta telnet rlogin udptn
line 5/00 5/01
no modem InOut
no modem status-poll
no modem log rs232
line 5/02 5/323
modem InOut
no modem log rs232
end
thomas.chen
Level 6
Level 6
clear the vty lines so that the async ports get shutsdown.
