cisco 4900m, pbr, route-map
Lukasz Bogucki
My customer has a question, what is the limit for entries for the route-map for PBR that will be done in hardware? This applies to soft-4900M 12.2 (53) SG2. I need a reference to documentation.
lb
rsimoni
Hi Lukasz,
the 4900M is a Data Center Switch and not a Metro one, so it is more appropriate if you post these types of questions on Network Infrastructure > LAN Switching and Routing section
(the 4900M should not be confused with the ME4900 series, which are Metro switches instead).
Anyway it supports 128.000 Security and Quality-of-Service (QoS) Hardware Entries as documented here:
http://www.cisco.com/en/US/products/ps6021/prod_models_comparison.html
and here:
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
regards,
Riccardo
rsimoni
Hi Lukasz,
and here:
regards,
Riccardo
lb
