Cisco ASR920 and l2protocol peer lacp
lbjwusatx
I have a Ethernet frame coming over a eLine across a service provider cloud into the ASR920. The Ethernet frame has LACP.
I was wondering is there a way for the ASR920 to establish the LACP peering relationship without having to resort to an external loop or LACP from another device?
I had understood that was the purpose of " l2protocol peer lacp" however, that appears to only be the case if you set up a Port-Channel and have a channel-group on a physical interface (not a service instance).
0 Replies 0
