Comcast P2P EDI Setup Help! Please
alschappell389
Hey Everyone,
So we just got setup with the Comcast P2P EDI Fiber. They never told me we needed to fo the L3 ourselves, so luckily we have a Cisco 4948 that can do some of that. I had this working the other day but we had a power outage and my cisco went to rommon so I lost everything and no I can not get it working again! So frustrating. Here is some info... The fiber comes out of Juniper into our Cisco Catalyst 4989 which then I have two ports on vlan to go to two seperate Barracuda firewalls which have seperate public ips. For some reason if I set my laptop to a static public ip it works but does not if I plug it into the Barracuda. Does all of this look correct?
Link IP Address:
50.238.244.248/30
Usable IP Block:
50.238.245.0/28
Gateway:
50.238.244.249
Usable IP Ranges:
50.238.245.2 thru 50.238.245.14
Layer 3 IP:
50.238.244.250
Usable Subnet Mask:
255.255.255.240
Layer 3 Subnet Mask:
255.255.255.252
Usable IPv6 Block:
N/A
DNS Information
Geographic Location:
National DNS Servers
Primary DNS:
75.75.75.75
Secondary DNS:
75.75.76.76
Running Config:
Switch#show running-config
Building configuration...
Current configuration : 2636 bytes
version 15.0
no service pad
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip vrf EDI
ip vrf mgmtVrf
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1
ip vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface GigabitEthernet1/21
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
interface GigabitEthernet1/46
switchport access vlan 80
interface GigabitEthernet1/47
interface GigabitEthernet1/48
no switchport
ip vrf forwarding EDI
ip address 50.238.244.250 255.255.255.252
interface TenGigabitEthernet1/49
interface TenGigabitEthernet1/50
interface TenGigabitEthernet1/51
interface TenGigabitEthernet1/52
interface Vlan1
no ip address
interface Vlan80
description Comcast LAN Block
ip address 50.238.245.1 255.255.255.240
ip route vrf EDI 0.0.0.0 0.0.0.0 50.238.244.249
ip http server
line con 0
stopbits 1
line vty 0 4
end
ilirnako1
You must to connect the firewalls at the ports: GigabitEthernet1/46  and GigabitEthernet1/47
.These ports are members of your inside Vlan 80
Ilir
Well yeah of course I know that . Im not really sure what happened but I enabled ip routing, walked away for 10 minutes, and then it started working. But if anyone else ever needs this type of information. The above config works. Im lucky i found some information while browsing.
