Connect ES/ES+ TG to 6708 line card ?
Amir Mehri
Hello
I need to connect ES/ES+ on 7613 to 6708 on 6513. this is my question, can i do this ? and does line protocol up in this case or not ? and is there any document about this ?
and another question that is, can i use 6513 with 6708 line card in core layer in metro ethernet network and is there any document that recommended this case ?
thank you
3 Accepted Solutions
WS-X6xxx LAN cards will use PFC for MPLS operations.
For these cards, EoMPLS is supported, VPLS isn't.
For VPLS, you need ES, ES+ or SIP cards.
For PFC MPLS features, check this page: http://www.cisco.com/en/US/docs/routers/7600/ios/15S/configuration/guide/pfc3mpls.html
For ES20, check this page:
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES20_config_guide/baldcfg.html#wp1584356
For ES+, check this page:
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap6.html
Cheers
Hi Amir,
due to formatting the topology is not too clear.
However if the 7600 with ES+ will be the PE's and the Cat6500 with 6708 just P's routers you can have VPLS in your scenario (VPLS with Ethernet Access) as I can see that the ES+ on the 7600 are facing the MPLS core.
Riccardo
Hi Amir,
you need ES+ on N-PE side facing the U-PE's only for MPLS access, that is having MPLS also between U-PE and N-PE.
If the access network is just IP there is no need for ES+ and 6724 will do fine.
Riccardo
PS: please flag the question as answered if you are happy.
8 Replies 8
rsimoni
Hello Amir,
yes you can connect ES/ES+ cards to 6708 and yes you can use 6708 card on cat6513.
About the documentation I don't think that such docs do exist.
Riccardo
Thank you Riccardo
Well, I have another question now, in our project, we use four 6513 in core and seven 7613 in aggregation. We want to use ES+ TG on 7613 for trunk and connect them to 6708 on 6513. We use 6148 and 6724 line card on 7613 for down link to 3400 metro access switch. Now I want to know where I can run VPLS and EoMPLS and Local Switching in this case or not ?
I would really appreciate some help.
Thank you
Cheers
Thank you Andre
I really worried about our project, do you mean, we can’t run VPLS with below scenario.
ME3400 < --- > 6724 line card ( 7613 ) ES+20 < --- > 6708 ( 6513 ) 6708 < --- > 6708 ( 6513 ) 6708 < --- >  ES+20 ( 7613 ) 6724 line card < --- > ME3400
                                              < PE-------------------------------------P----- ----------- MPLS -- -----P------------------------------------PE- >
Hi Amir,
Riccardo
tahnk you ricardo
i attached jpeg file of my scenario and have another question, do i need to use ES+ on N-PE ( 7613) for U-PE side ?
i need H-VPLS and VPLS and EoMPLS.
Hi Amir,
Riccardo
thank you very much dear Riccardo
