EoMPLS configuration using EVC
sezaar
Visitor
Hello all,
I have a situaton where i need to do EoMPLS ( xconnect) between two Pe's using EVC.
problem is that from one side iam getting the frame with dual tag QinQ and from second PE its only one tag.
Note the decives are 7600 PE's
is this possible and how can it be done.
thanks
Vinit Jain
Could you please share the configuration from both the PE routers.
Vinit
--Vinit
Thank you Vinit.
My question was more about the consept. anyhow its solved any working now.
Thanks again.
Hello Sezaar,
how have you solved your issue? Providing this feedback would make this thread more useful for other people.
Best Regards
Giuseppe
arnon l
Community Member
look at this link:
http://ccie-in-3-months.blogspot.co.il/2009/06/evc-flexible-vlan-tag-rewrite.html
