hello
I'm having a problem with the implementation of a ASR9010 G8032, I have a ring of switches from another vendor and when I place an debbug get the following error:
erp_io [156]: PKT: rcvd Gi0/1/0/3.10 R-APS (NR) [0]: req 00 status 00, node_id dcd2.fc72.9f50
erp_io [156]: ERR: 0 Packet With Wrong version or opcode 40
erp_io [156]: PKT: rcvd Gi0/1/0/5.10 R-APS (NR) [0]: req 00 status 00, node_id dcd2.fc72.9f50
Using 9010 as an aggregator to metro, ring closure in the same aggregator
the config applied is as follows:
ethernet ring g8032 profile RING
timer wtr 1
guard timer 100
timer hold-off 1
interface GigabitEthernet0/1/0/3.10 l2transport
encapsulation dot1q 10
rewrite ingress tag pop 1 symmetric
interface GigabitEthernet0/1/0/5.10 l2transport
l2vpn
tcn-propagation
ethernet ring g8032 RING_0001
interface port0 GigabitEthernet0/1/0/3
monitor interface GigabitEthernet0/1/0/3.10
port1 interface GigabitEthernet0/1/0/5
monitor interface GigabitEthernet0/1/0/5.10
instance 1
profile RING
inclusion-list vlan-ids 1-4094
aps-channel
level 7
port0 interface GigabitEthernet0/1/0/3.10
port1 interface GigabitEthernet0/1/0/5.10
bridge group RING
bridge-domain ERPS
Placing a probe interface as RPL Owner agragador
I would appreciate if you can help
thanks
