Implementing REP
Rafael Jimenez
Level 7
Level 7
I have a metro ethernet ring with 13 ME swithces in production with spaning tree. I want implement REP. What is the best way to configure the REP Ports, in order to have the less amount of network interruptions  ?
silvio.lui
Frequent Visitor
Frequent Visitor
Hi Rafael,
When you active the REP, automaticaly STP will be disable on the interface that are included in the segment.
Try this:
1 - Select that will be the Edge Switch in the ring and shut one interface to avoid loop;
2 - Select a VLAN Admin tha will be used by REP and config in all trunks segment ring;
    Ex:  rep vlan admin
3 - Config the all REP Transit Switches;
     Ex: int giga0/1
              rep segment 1
           int giga0/2
              rep segment 1
4 - Config the Edge Switch:
     Ex: int giga0/1
              shutdown
              rep segment 1 edge primary
           int gia0/2
              rep segment 1 edge
5 - Verify if the REP topology will be created, and the port that be shutdown is in Fail:
      Ex: show rep topology
REP Segment 1
Warning:
REP detects a segment failure, topology may be incomplete
BridgeName       PortName   Edge Role
ME_EDGE             Gi0/1          Fail
ME_EDGE             Gi0/2          Open
ME_TRANST           Gi0/2          Open
ME_TRANST           Gi0/1     Sec  Open
6 - Return to UP the shutdown port, and verify de topology again:
REP Segment 1
ME_EDGE             Gi0/1     Pri  Open
ME_EDGE             Gi0/2          Open
ME_TRANST           Gi0/1     Sec  Alt
*** the 'Alt' status is the port in block mode to avoid loop.
I hope help!
Regards!
Silvio L. Veira
Silvio Silva
Thanks Silvio,
My main concern is what will happen when I run the first command rep segment 1 in the first interface, there will be a network outage? for how long ?
What will happen when I configure the transit switches with the rep segment 1,  there will be a network outage? for how long ?
What happens when I type the command rep block port preferred vlan all on edge primary,  there will be a network outage? for how long ?
What is the risk and the best way to avoid loss conectivity to my telnet session?
