IP dhcp snooping issue on ASR920
Adis Cato
Hi Cisco kids,
Recently my company sold Cisco ASR 920 routers to an ISP customer. Pretty cool device, the customer wants to integrate this router in the network as a PE device and everything is fine except strange problem with DHCP snooping feature.
Platform: ASR-920-24SZ-M
IOS: asr920-universalk9_npe.03.16.02a.S.155-3.S2a-ext.bin (Cisco recommended)
We have multicast configured for the IPTV service, customers are connected via access ports (ASR920>DSLAM>SET-UP BOX) configured like this:
interface GigabitEthernet0/0/0
 description DSLAM_XXXXXX
service instance 934 ethernet
  encapsulation dot1q 934
  rewrite ingress tag pop 1 symmetric
  bridge-domain 934 split-horizon group 0
L3 interface that is used as a gateway for IPTV users:
interface BDI934
 description IPTV_Aggregation_and_access
 ip address 10.16.112.1 255.255.240.0 secondary
 ip address 10.71.240.1 255.255.240.0
 ip helper-address 10.120.1.47
 ip helper-address 10.120.25.48
 ip flow ingress
 ip pim passive
 ip access-group 105 in
 ip ospf 8000 area 0
 load-interval 30
end
And we have dhcp snooping configuration:
ip dhcp snooping
ip dhcp snooping bridge-domain 934
ip dhcp snooping track host
no ip dhcp snooping information option
When IP dhcp snooping feature is enabled SET-UP box devices cannot get an IP address from the DHCP server, located in a data center (10.120.1.47, 10.120.25.48). I have configured a one port as an access and connect the laptop to it for troubleshooting purposes:
interface GigabitEthernet0/0/17
 description TEST_LAPTOP
 no ip address
 negotiation auto
  encapsulation untagged
  bridge-domain 934
End
We have two uplink interfaces configured to connect us to the IP/MPLS network:
interface GigabitEthernet0/0/22
description --Veza prema C7609_PE_XXXX-Gi-8/14 --
 mtu 9178
 ip address 10.100.103.205 255.255.255.252
 ip pim sparse-mode
 ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 7 03540E1B004131181B5C
 ip ospf network point-to-point
 ip ospf hello-interval 1
 ip ospf 8000 area 0
 load-interval 30
 negotiation auto
 mpls ip
 mpls label protocol ldp
 mpls traffic-eng tunnels
 mpls traffic-eng backup-path Tunnel2280
 cdp enable
 service-policy input MPLS_LLQ_WAN_INPUT
 service-policy output MPLS_LLQ_WAN_PARENT
 ip rsvp bandwidth
 ip rsvp signalling hello
end
Current configuration : 635 bytes
interface GigabitEthernet0/0/23
 description --Veza prema C7606_PE_XXXX-Gi-1/23 --
 mtu 9178
 ip address 10.100.103.201 255.255.255.252
 ip pim sparse-mode
 ip ospf 8000 area 0
 ip ospf cost 11
 load-interval 30
 negotiation auto
 mpls ip
 mpls traffic-eng backup-path Tunnel2270
 cdp enable
 ip rsvp bandwidth
end
And when dhcp snooping is enabled laptop cannot get an IP, after we disable dhcp snooping everything is working just fine. We have the same configuration on hundreds other locations, but on different platforms (C7600, ME3600...) and it works perfect, only on ASR 920 we have this issue.
We have tried with debug and got this message:
DHCP_SNOOPING: can't find output interface for dhcp reply. the message is dropped.
I went through the available Cisco documentation but did not find anything.. Can somebody had similar experience or some advice.
Thank you in advance.
Andrew Judson
Community Member
What is the output of
show bridge-domain 934
does it differ with DHCP_Snooping on/off
could try removing split horizon, not needed in this case
Hi Andrew,
I have tried to remove split horizon configuration, but still facing the same issue...
not hitting CSCur76202?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur76202
try the fixed IOS releases
Hi Andrew,
We have 3.16.3aS(ED) Cisco recommended version installed on the router.
We are manage to figure it out that problem with dhcp snooping is with customers connected to the Alcatel DSLAM equipment. We do some testing and realize that if dhcp snooping is enabled, CPE equipment connected to the Alcatel DSLAM can not get an IP address. If we disable dhcp snooping, CPE gets an IP address. Test results also showed that if we enable the „ip dhcp snooping information option“ command on the router it works as well.
Thank you for your reply.
Adis Cato
