L2TPv3 tunnel
Mukesh Kumar
Level 3
Level 3
I have to configure L2TPv3 tunnel between two ends on 2921 routers.
Can anybody tell me while configuring xconnect interface the following config will work or not?
R1
pseudowire-class test
encapsulation l2tpv3
ip local interface f0/0
interface f0/0
ip address 1.1.1.1 255.255.255.252
interface FastEthernet0/1
xconnect 2.2.2.2 1 encapsulation l2tpv3 pw-class test
R3
interface f0/0
ip address 2.2.2.2 255.255.255.252
interface FastEthernet0/1.1
encapsulation dot1Q 5
xconnect 1.1.1.1 1 encapsulation l2tpv3 pw-class test
As i have done this config the tunnel is down. When i define xconnect on R3 on the physical interface instead of sub-interface it becomes up.
Is there any prerequisite that we require physical interfaces for xconnect on both end or same encapsulation defined in the subinterface on both ends?
Mukesh Kumar
Network Engineer
Spooster IT Services
Alex Sanchez Jimenez
Mukesh,
The only problem I can see is that you have VLAN 5 on the subinterface, but not on the main interface, this means that the traffic might not get to the other end due to the Dot1q encapsulation. If you were to set both to the same dot1q tag it should come up.
Alex Sanchez
CCIE R&S #37454
