em 12-20-2011 01:22 PM
We are using ME3400 switches at each of our sites to connect to a MPLS IP VPN from a service provider. The provider does not provide encryption of our data. Does the ME3400 switch support IPSec or GET VPN? If not, is there a way to encrypt our data using the ME3400 switches before it passes through the MPLS network?
em 12-20-2011 01:33 PM
neither of the options are supported I am afraid.
You could either start encryption before traffic enters the ME3400, or consider a 3-d party l2 encryptors.
HTH,
Ivan.
em 12-21-2011 08:06 AM
Do you know if they support NetFlow?
em 12-21-2011 08:24 AM
ME3400 does not support NetFlow due to hardware limitation.
HTH,
Ivan.
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
