me3750 QoS
jamesliu20800
Hi, There:
I read cisco ME-3750 doc. it seems most of QoS feature supported only ES port, will standard port support priority queueing and shaping? it seems there is not clear document..
~mike
smalkeric
Level 6
Level 6
I think only the ES ports support enhanced features such as bidirectional Hierarchical QoS and Traffic Shaping, intelligent 802.1Q tunneling, VLAN translation, MPLS, EoMPLS, and H-VPLS.
Joseph W. Doherty
If I'm reading the ME-3750 documentation correctly, it appears non-ES ports have the same QoS featues as a "normal" 3750. I.e. both support priority queuing and shaping, although not by using a policy-map. For example, see http://www.cisco.com/en/US/docs/switches/metro/catalyst3750m/software/release/12.2_50_se/configuration/guide/swqos.html#wp1021247
