Per vlan or Per IP based Rate Shaping or Limiting using 6500s ? Possible?
martin_tsang
Posted by: martin_tsang - Network Engineer, BigAir - Dec 1, 2005, 6:22pm PST
1. Is it possible to do per IP based rate shaping or rate-limiting in both directions?
2. Is this possible without some special card which costs heaps of $$$.
3. Is it possible to do per vlan rate shaping?
4. I have tried to look for help from cisco, but it seems to revolve around GTS.
IOS (tm) c6sup1_rp Software (c6sup1_rp-PSV-M), Version 12.1(22)E1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 16-Apr-04 10:13 by pwade
Image text-base: 0x60020F90, data-base: 0x616EA000
ROM: System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE
BOOTLDR: MSFC Software (C6MSFC-BOOT-M), Version 12.1(3a)E4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
uptime is 1 year, 20 weeks, 6 days, 21 hours, 37 minutes
Time since xxxxxx switched to active is 1 year, 20 weeks, 6 days, 21 hours, 40 minutes
System returned to ROM by power-on (SP by reload)
System restarted at 14:23:56 AEST Thu Jul 8 2004
System image file is "slot0:c6sup11-psv-mz.121-22.E1"
cisco WS-C6506 (R5000) processor (revision 3.0) with 114688K/16384K bytes of memory.
Processor board ID TBA05290886
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
30 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
4096K bytes of packet SRAM memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
Thanks in advance for any tips/hints/guides you may provide.
Cheers
martin
Marvin Rhoads
Assuming you have a Sup-1a with PFC (or greater), you can use QoS policing. See the following reference for details:
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_tech_note09186a00801c8c4b.shtml
One can apply policing on a per-VLAN or per-port basis.
