We have two 7206 routers terminating pppoe sessions for a single VLAN. We have tried using the "pppoe limit max-sessions" command on the VPDN group, on one of the routers. After applying the command, no new sessions are established on the router with the command applied. Over time, sessions actually drop off and reauthenticate/terminate through the router without the command applied. Has anyone else seen this problem?
RR
